发表于 2011-5-6 18:49:27
unless you want to use your own header file or a particular instance of a customized header file, use the header file provided by the compiler.
so instead of what you wrote above, use
and better yet, use the vendor specific header file. like regx52 if you are using certain atmel '52 chips. |
