楼主: 老郑小烧
分享原创:机械表头的线性度与度盘的绘制——《分度》V1.0
发表于 2023-12-24 19:49:30 | 显示全部楼层
收藏了,慢慢学习,对cad了解少,现在还看不太懂
 楼主| 发表于 2023-12-24 21:16:59 | 显示全部楼层
没涉及太多CAD操作,CAD我也是刚熟练点儿。
EXCEL主要是按分度函数连接公式,已经连接好的只改参数就行,比如欧姆标尺把22改成16.5。
 楼主| 发表于 2023-12-24 22:23:32 | 显示全部楼层
用分度1.0画了个110度量角器(用工具画工具 ),适用于测量大多数表头。
效果和源文件如下。镜窗可镂空,背面贴上反光纸。
分度 V1.0_110度量角器.zip (182.16 KB, 下载次数: 162)
发表于 2023-12-24 22:48:30 来自手机 | 显示全部楼层
谢谢老师的分享。
发表于 2023-12-24 23:42:58 | 显示全部楼层
I highly appreciate your effort ! Anyone have thinking about way to make owner meter panel in aluminum ?
 楼主| 发表于 2023-12-25 00:47:42 | 显示全部楼层
chihaxinh 发表于 2023-12-24 23:42
I highly appreciate your effort ! Anyone have thinking about way to make owner meter panel in alumin ...
Thank you!
Regarding production, it is indeed an issue. Based on cost and available processing suppliers, I have considered using materials such as hard plastic.
发表于 2023-12-25 16:12:03 | 显示全部楼层
老郑小烧 发表于 2023-12-25 00:47
Thank you!
Regarding production, it is indeed an issue. Based on cost and available processing s ...
Thank you !
Dont worry about english, You can type in Chinese Mandarin i can using baidu translate to understand what you said .
Another way , if you can type and understand English, hope you can make bridge to communicate with me and other member in forum !
I join and read forum crystalradio about 2 years ago , and I have learned so much from you and another master in forum.
Like "Magnertizer Meter Movement" , "Active Meter by using opamp" , " Convert analog to Active Meter" , and many more topic i can't list complete in here.
Thank you !
发表于 2023-12-25 16:17:23 | 显示全部楼层
铝制仪表板可以找集成吊顶扣板做,就是不好打印。
发表于 2023-12-25 16:23:13 | 显示全部楼层
高级工程师级别的专业讲解,牛!
发表于 2023-12-25 16:43:21 | 显示全部楼层
I think we can make pcb with copper etching by HCL + H202 and UV Photosensitive Dry Fiml . Same process diffirent etching liquid ( Alumimum can etching by FeCl2 ). Or we can use UV Ink to make Dial Meter
 楼主| 发表于 2023-12-25 16:44:09 | 显示全部楼层
chihaxinh 发表于 2023-12-25 16:12
Thank you !
Dont worry about english, You can type in Chinese Mandarin i can using baidu translat ...
感谢理解 !我需要借助百度翻译才能“写”,尤其是涉及到专业方面的话题。
我在这个论坛学到了不少东西,然后才做了些研究。所以,我希望这些成果能对大家有用,并且不断完善。
发表于 2023-12-25 16:45:34 | 显示全部楼层
使用Excel VBA操控Auto CAD,这个作品很高大上!
 楼主| 发表于 2023-12-25 16:57:59 | 显示全部楼层
chihaxinh 发表于 2023-12-25 16:43
I think we can make pcb with copper etching by HCL + H202 and UV Photosensitive Dry Fiml . Same pr ...
蚀刻是个办法。
现在的限制条件是业余条件下如何实现,另外蚀刻的分辨率能达到多少?
 楼主| 发表于 2023-12-25 17:00:48 | 显示全部楼层
下个版本要加些功能。在此之前,若有反馈会一并考虑
发表于 2023-12-25 17:05:22 来自手机 | 显示全部楼层
制作表盘可以考虑,用PCB制作,打印PCB的厚度可以薄点
GMT+8, 2025-4-26 06:07
