号 功率 增益 电压 频率 工作状态 封装 123脚
国外三极管
2N3375 10W 5dB 28V 400MHz FM/AM/SSB TO-60
2N3553 2.5W 10dB 28V 175MHz FM/AM TO-39 C B E
2N3632 20W 7dB 28V 175MHz FM TO-60
2N3866 5W 10dB 28V 400MHz WINTransceiver TO-39 C B E
2N3924 4W 6dB 13.6V 175MHz WINTransceiver TO-39
2N4427 2W 10dB 12V 175MHz WINTransceiver TO-39
2N5108 1W 5dB 24V 1200MHz WINTransceiver TO-39
2N5109 3.5W 11dB 15V 200MHz WINTransceiver TO-39
2N5421 3W 9dB 13.5V 175MHz WINTransceiver TO-39
2N5913 2W 7dB 12.5V 175MHz WINTransceiver TO-39
2N5943 1W 8dB 15V 400MHz FM TO-39
2SC730 0.8W 10dB 13.5V 175MHz FM TO-39 C B E
2SC1096 10W 60MHz FM TO-220
2SC1173 10W 100MHz FM/AM/SSB TO-220
2SC1306 16W 30MHz FM/AM/SSB TO-220 B C E
2SC1307 16W 12dB 12V 30MHz FM/AM/SSB TO-220 B C E
2SC1590 5W 10dB 12.5V 136-174MHz FM TO-220 B E C
2SC1591 14W 7.5dB 12.5V 136-174MHz FM TO-220 B E C
2SC1674 0.5W 18dB 30V 600MHz FM/AM E C B
2SC1675 0.5W 50V 250MHz FM/AM
2SC1678 5W 30MHz WINTransceiver TO-220 B C E
2SC1728 8W 80MHz WINTransceiver TO-202 E B C
2SC1729 14W 10dB 13.5V 175MHz FM T-31E
2SC1906 0.1W 18dB 12V 1000MHz FM
2SC1907 0.1W 30V 1100MHz FM
2SC1909 10W 14.5dB 13.5V 50MHz FM/AM/SSB TO-220 B C E
2SC1944 13W 11.1dB 12V 30MHz WINTransceiver TO-220 B C E
2SC1945 16W 14.5dB 12V 30MHz FM/AM/SSB TO-220 B E C
2SC1946 25W 6.7dB 13.5V 175MHz FM T-31E
2SC1946A 30W 10dB 13.5V 175MHz FM T-31E
2SC1947 3W 10dB 13.5V 175MHz FM TO-39 C B E
2SC1957 1.8W 17dB 12V 30MHz WINTransceiver TO-126 E C B
2SC1966 9W 7.8dB 13.5V 470MHz FM T-31E
2SC1967 7W 6.7dB 13.5V 470MHz FM T-31E
2SC1968 14W 3.7dB 13.5V 470MHz FM T-31E
2SC1968A 14W 5.4dB 13.5V 470MHz FM T-31E
2SC1969 18W 12dB 12V 30MHz FM/AM/SSB TO-220 B C E
2SC1970 1.5W 9.2dB 13.5V 175MHz WINTransceiver TO-220 B C E
2SC1971 7W 10dB 13.5V 175MHz WINTransceiver TO-220 B E C
2SC1972 14W 7.5dB 13.5V 175MHz WINTransceiver TO-220 B E C
2SC1973 1W 50MHz WINTransceiver TO-92L B C E
2SC1974 13W 10dB 13.5V 30MHz WINTransceiver TO-220 B C E
2SC1975 4W 10dB 13.5V 30MHz WINTransceiver TO-220 B C E
2SC2028 1.8W 30MHz WINTransceiver TO-126 E C B
2SC2029 6W 30MHz WINTransceiver TO-220 B C E
2SC2036A 1.4W ***** WINTransceiver TO-202 B C E
2SC2050 10W 12dB 13.5V 30MHz FM/AM/SSB TO-220 B C E
2SC2053 0.2W 15.7dB 12V 175MHz FM/AM TO-92L B C E
2SC2055 0.25W 15.3dB 12V 175MHz FM/AM TO-92L B C E
2SC2056 1.5W 9dB 12V 175MHz FM TO-39 C B E
2SC2075 4W 13.5V 27MHz WINTransceiver TO-220 B C E
2SC2078 4W 13dB 12V 100MHz FM/AM TO-220 B C E
2SC2086 0.45W 13dB 12V 175MHz FM/AM TO-92L B C E
2SC2092 4W 13dB 12V 100MHz FM/AM/SSB TO-220 B C E
2SC2094 15W 8.8dB 13.5V 175MHz FM/AM/SSB T-31E
2SC2166 6W 13.8dB 12V 30MHz FM/AM/SSB TO-220 B C E
2SC2207 16W 27MHz WINTransceiver TO-220 B C E
2SC2237 6W 13.8dB 13.5V 175MHz FM T-31E
2SC2312 18.5W 27MHz FM/AM/SSB TO-220 B C E
2SC2314 1.8W 17dB 12V 180MHz FM/AM TO-126 E C B
2SC2509 13W 14dB 30MHz WINTransceiver TO-220 B C E
2SC2527 60W 80MHZ WINTransceiver TO-220
2SC2538 0.6W 10dB 12V 175MHz FM/AM TO-92L B C E
2SC2539 14W 14.5dB 13.5V 175MHz FM T-31E
2SC2558 1.3W 12dB 960MHz
2SC2630 60W 175MHz
2SC2660 30W 30MHz WINTransceiver TO-220
2SC2668 0.1W 18dB 40V 550MHz FM
2SC2695 30W 5dB 13.5V 520MHz FM T-31E
2SC2851 0.9W 9dB 175MHz FM
2SC2905 50W 5dB 512MHz
2SC2932 6W 8dB 960MHz
2SC3001 6W 13dB 7.2V 175MHz FM T-31E
2SC3017 1W 11dB 13.5V 175MHz FM TO-39 C B E
2SC3018 3W 13dB 7.2V 175MHz FM T-31E
2SC3019 0.6W 14dB 512MHz
2SC3020 3W 10dB 12.5V 520MHz FM T-31E
2SC3021 7W 7.7dB 12.5V 520MHz FM T-31E
2SC3022 18W 4.8dB 12.5V 520MHz FM T-31E
2SC3103 2.8W 6.7dB 7.2V 520MHz FM T-31E
2SC3104 6W 4.8dB 7.2V 520MHz FM T-31E
2SC3133 13W 14dB 12V 1.5-30MHz FM/AM/SSB TO-220 B E C
2SC3174 60W 7dB 175MHz
2SC3297 15W 100MHz WINTransceiver TO-220
2SC3299 20W 120MHz WINTransceiver TO-220
2SC3355 0.6W 12V 6500MHz FM/TV B E C
2SC3358 0.5W 12V 7000MHz UHF
2SC3668 1W 50V 100MHz WINTransceiver
2SC3700 30W 960MHz
2SC3702 80W 960MHz
2SC3807 15W 260MHz WINTransceiver TO-126
2SC4137 4W 400MHz WINTransceiver TO-126
2SC4167 8W 8dB 512MHz
2SC4693 0.9W 12V 2500MHz FM/AM TO-92L B C E
2SD467 0.5W 12V 280MHz FM/AM
2SD468 0.9W 12V 190MHz FM/AM
BFQ43 4W 12dB 13.5V 175MHz
BFR96 0.3W 13.5dB 12V 5000MHz UHF
BFR96S 0.5W 9dB 12V 5000MHz UHF
BLT50 1.2W 512MHz
BLT53 8W 7dB 512MHz
BLT80 0.8W 6dB 960MHz
BLT81 1.2W 7dB 960MHz
BLU99 5W 10dB 512MHz
BLV59 30W 11dB 900MHz
BLV97 35W 11dB 900MHz
BLV99 2W 11dB 900MHz
BLV100 8W 11dB 900MHz
BLV101 50W 11dB 900MHz
BLV103 4W 11dB 900MHz
BLV2045 35W 9dB 2000MHz
BLW81 10W 7dB 512MHz
BLX65 2W 9dB 512MHz
BLY87C 8W 12dB 175MHz
BLY88A 15W 9dB 175MHz
KTC1006 1W 100MHz FM/AM TO-92L E C B
KTC1969 16W 12dB 12V 100MHz FM/AM TO-220 B C E
KTC2078 4W 11dB 12V 100MHz FM/AM TO-220 B C E
MGF0905 40W 34dB 2000MHz
MLF503 3W 11dB 7.5V 500MHz
MLF507 7W 11dB 12V 500MHz
MFF208 10W 11dB 2000MHz
MRF134 5W 14dB 400MHz
MRF136 15W 16dB 400MHz
MRF161 5W 13.5dB 12.5V 225-500MHz FM/AM TO-220 B E C
MRF162 15W 13.5dB 12.5V 225-500MHz FM/AM TO-220 B E C
MRF163 25W 12dB 12.5V 225-500MHz FM/AM TO-220 B E C
MRF182 30W 14dB 1000MHz
MRF184 60W 11.5dB 1000MHz
MRF237 4W 12dB 18V 175MHz WINTransceiver TO-39
MRF260 5W 10dB 12.5V 136-174MHz FM TO-220 B E C
MRF261 10W 5.2dB 12.5V 136-174MHz FM TO-220 B E C
MRF262 14W 7.5dB 12.5V 136-174MHz FM TO-220 B E C
MRF264 30W 5.2dB 12.5V 136-174MHz WINTransceiver TO-220 B E C
MRF314 30W 10dB 175MHz
MRF340 8W 13dB 28V 70MHz WINTransceiver TO-220 B E C
MRF342 24W 11dB 28V 70MHz WINTransceiver TO-220 B E C
MRF344 60W 6dB 28V 70MHz WINTransceiver TO-220
MRF454 80W 12dB 12.5V 1.5-30MHz FM/AM/SSB
MRF455 60W 13dB 12.5V 1.5-30MHz FM/AM/SSB
MRF475 12W 10dB 13.5V 1.5-30MHz FM/AM/SSB TO-220 B C E
MRF476 3W 15dB 13.5V 1.5-30MHz FM/AM/SSB TO-220 B C E
MRF477 40W 15dB 13.5V 1.5-30MHz FM/AM/SSB TO-220 B E C
MRF479 15W 10dB 13.5V 1.5-30MHz FM/AM/SSB TO-220
MRF485 15W 10dB 28V 1.5-30MHz WINTransceiver TO-220
MRF486 40W 15dB 28V 1.5-30MHz WINTransceiver TO-220
MRF496 40W 15dB 13.5V 1.5-30MHz WINTransceiver TO-220
MRF497 60W 10dB 13.5V 27-50MHz WINTransceiver TO-220 B E C
MRF517 0.75W 10dB 20V 1000MHz WINTransceiver TO-39
MRF553 1.5W 9dB 175MHz
MRF559 0.5W 900MHz
MRF607 1.75W 11.5dB 16V 175MHz WINTransceiver TO-39
MRF630 4W 10dB 13.5V 512MHz FM TO-39
MRF650 50W 5dB 512MHz
MRF652 5W 10dB 512MHz
MRF859 6.5W 11dB 900MHz
MRF660 7W 5.4dB 12.5V 400-512MHz WINTransceiver TO-220
MRF844 30W 960MHz
MRF846 40W 960MHz
MRF847 45W 960MHz
MRF857 2W 11dB 900MHz
MRF858 3.6W 11dB 900MHz
MRF891 5W 9dB 900MHz
MRF899 150W 11dB 900MHz
MRF2062 1.2W 15dB 2000MHz
MRF2628 15W 12dB 175MHz
MRF8372 0.75W 8dB 960MHz
MRF20060 60W 9dB 2000MHz
MRF20082 15W 9dB 2000MHz
MRF20146 0.6W 10dB 2000MHz
MRF20147 4W 10dB 2000MHz
MRF20170 30W 8.5dB 2000MHz
MS1226 30W 18dB 28V 30MHz FM/AM/SSB
MS1227 20W 15dB 12.5V 30MHz FM/AM/SSB
SD1477 100W 175MHz
TP3007 2W 9dB 900MHz
TP3008 4W 11.5dB 900MHz
TP3020 2.2W 9dB 900MHz
TP3022 15W 9dB 900MHz
TP3024 35W 7.5dB 900MHz
TP5002 2W 13dB 510MHz
TP5015 15W 11dB 510MHz
国内三极管
3DA21A 7.5W 10dB 15V 400MHz FM/AM
3DA21B 7.5W 10dB 25V 400MHz FM/AM
3DA22A 15W 10dB 15V 400MHz FM/AM
3DA22B 15W 10dB 25V 400MHz FM/AM
3DA23A 30W 15V 500MHz FM/AM
3DA23B 30W 12V 500MHz FM/AM
3DA23C 30W 20V 500MHz FM/AM
3DA24A 2W 15V 1000MHz FM
3DA24B 2W 15V 1000MHz FM
3DA190 2W 35V 600MHz
3DA191 5W 35V 600MHz
3DA192 7.5W 35V 600MHz
3DA193 15W 35V 600MHz
3DA194 2W 35V 1GHz |
