型号 功率 增益 电压 频率 工作状态 封装 123脚
2N3375 10W 5dB 28V 400MHz FM/AM/SSB TO-60
2N3553 2.5W 10dB 28V 175MHz FM/AM TO-39 CBE
2N3632 20W 7dB 28V 175MHz FM TO-60
2N3866 5W 10dB 28V 400MHz WINTransceiver TO-39 CBE
2N3924 4W 6dB 13.6V 175MHz WINTransceiver TO-39
2N4427 2W 10dB 12V 175MHz WINTransceiver TO-39
2N5108 1W 5dB 24V 1200MHz WINTransceiver TO-39
2N5109 3.5W 11dB 15V 200MHz WINTransceiver TO-39
2N5421 3W 9dB 13.5V 175MHz WINTransceiver TO-39
2N5913 2W 7dB 12.5V 175MHz WINTransceiver TO-39
2N5943 1W 8dB 15V 400MHz FM TO-39
2SC730 0.8W 10dB 13.5V 175MHz FM TO-39 CBE
2SC1096 10W 60MHz FM TO-220
2SC1173 10W 100MHz FM/AM/SSB TO-220
2SC1306 16W 30MHz FM/AM/SSB TO-220 BCE
2SC1307 16W 12dB 12V 30MHz FM/AM/SSB TO-220 BCE
2SC1590 5W 10dB 12.5V 136-174MHz FM TO-220 BEC
2SC1591 14W 7.5dB 12.5V 136-174MHz FM TO-220 BEC
2SC1678 5W 30MHz WINTransceiver TO-220 BCE
2SC1728 8W 80MHz WINTransceiver TO-202 EBC
2SC1729 14W 10dB 13.5V 175MHz FM T-31E
2SC1909 10W 14.5dB 13.5V 50MHz FM/AM/SSB TO-220 BCE
2SC1944 13W 11.1dB 12V 30MHz WINTransceiver TO-220 BCE
2SC1945 16W 14.5dB 12V 30MHz FM/AM/SSB TO-220 BEC
2SC1946 25W 6.7dB 13.5V 175MHz FM T-31E
2SC1946A 30W 10dB 13.5V 175MHz FM T-31E
2SC1947 3W 10dB 13.5V 175MHz FM TO-39 CBE
2SC1957 1.8W 17dB 12V 30MHz WINTransceiver TO-126 ECB
2SC1966 3W 7.8dB 13.5V 470MHz FM T-31E
2SC1967 7W 6.7dB 13.5V 470MHz FM T-31E
2SC1968 14W 3.7dB 13.5V 470MHz FM T-31E
2SC1968A 14W 5.4dB 13.5V 470MHz FM T-31E
2SC1969 18W 12dB 12V 30MHz FM/AM/SSB TO-220 BCE
2SC1970 1.5W 10dB 13.5V 175MHz WINTransceiver TO-220 BEC
2SC1971 7W 10dB 13.5V 175MHz WINTransceiver TO-220 BEC
2SC1972 14W 10dB 13.5V 175MHz WINTransceiver TO-220 BEC
2SC1973 1W 50MHz WINTransceiver TO-92L BCE
2SC1974 13W 10dB 13.5V 30MHz WINTransceiver TO-220 BCE
2SC1975 4W 10dB 13.5V 30MHz WINTransceiver TO-220 BCE
2SC2028 1.8W 30MHz WINTransceiver TO-126 ECB
2SC2029 6W 30MHz WINTransceiver TO-220 BCE
2SC2036A 1.4W WINTransceiver TO-202 BCE
2SC2050 10W 12dB 13.5V 30MHz FM/AM/SSB TO-220 BCE
2SC2053 0.2W 15.7dB 12V 175MHz FM/AM TO-92L BCE
2SC2055 0.25W 15.3dB 12V 175MHz FM/AM TO-92L BCE
2SC2056 1.5W 9dB 12V 175MHz FM TO-39 CBE
2SC2075 4W 13.5V 27MHz WINTransceiver TO-220 BCE
2SC2078 4W 13dB 12V 100MHz FM/AM TO-220 BCE
2SC2086 0.45W 13dB 12V 175MHz FM/AM TO-92L BCE
2SC2092 4W 13dB 12V 100MHz FM/AM/SSB TO-220 BCE
2SC2094 15W 8.8dB 13.5V 175MHz FM/AM/SSB T-31E
2SC2166 6W 13.8dB 12V 30MHz FM/AM/SSB TO-220 BCE
2SC2207 16W WINTransceiver TO-220 BCE
2SC2237 6W 13.8dB 13.5V 175MHz FM T-31E
2SC2312 18.5W 27MHz FM/AM/SSB TO-220 BCE
2SC2314 1.8W 17dB 12V 180MHz FM/AM TO-126 BCE
2SC2509 13W 14dB 30MHz WINTransceiver TO-220 BCE
2SC2527 60W WINTransceiver TO-220
2SC2538 0.6W 10dB 12V 175MHz FM/AM TO-92L BCE
2SC2539 14W 14.5dB 13.5V 175MHz FM T-31E
2SC2660 30W 30MHz WINTransceiver TO-220
2SC2695 23W 1.9dB 13.5V 520MHz FM T-31E
2SC3001 6W 13dB 7.2V 175MHz FM T-31E
2SC3017 1W 11dB 13.5V 175MHz FM TO-39 CBE
2SC3018 3W 13dB 7.2V 175MHz FM T-31E
2SC3020 3W 10dB 12.5V 520MHz FM T-31E
2SC3021 7W 7.7dB 12.5V 520MHz FM T-31E
2SC3022 18W 4.8dB 12.5V 520MHz FM T-31E
2SC3103 2.8W 6.7dB 7.2V 520MHz FM T-31E
2SC3104 6W 4.8dB 7.2V 520MHz FM T-31E
2SC3133 13W 14dB 12V 1.5-30MHz FM/AM/SSB TO-220 BEC
2SC3297 15W 100MHz WINTransceiver TO-220
2SC3299 20W WINTransceiver TO-220
2SC3668 1W 100MHz WINTransceiver
2SC3807 15W 260MHz WINTransceiver TO-126
2SC4137 4W 400MHz WINTransceiver TO-126
2SC4693 FM/AM TO-92L BCE
KTC1006 1W 100MHz FM/AM TO-92L BCE
KTC1969 16W 12dB 12V 100MHz FM/AM TO-220 BCE
KTC2078 4W 11dB 12V 100MHz FM/AM TO-220 BCE
MRF161 5W 13.5dB 12.5V 225-500MHz FM/AM TO-220 BEC
MRF162 15W 13.5dB 12.5V 225-500MHz FM/AM TO-220 BEC
MRF163 25W 12dB 12.5V 225-500MHz FM/AM TO-220 BEC
MRF237 4W 12dB 18V 175MHz WINTransceiver TO-39
MRF260 5W 10dB 12.5V 136-174MHz FM TO-220 BEC
MRF261 10W 5.2dB 12.5V 136-174MHz FM TO-220 BEC
MRF262 14W 7.5dB 12.5V 136-174MHz FM TO-220 BEC
MRF264 30W 5.2dB 12.5V 136-174MHz WINTransceiver TO-220 BEC
MRF340 8W 13dB 28V 70MHz WINTransceiver TO-220 BEC
MRF342 24W 11dB 28V 70MHz WINTransceiver TO-220 BEC
MRF344 60W 6dB 28V 70MHz WINTransceiver TO-220
MRF454 80W 12dB 12.5V 1.5-30MHz FM/AM/SSB
MRF455 60W 13dB 12.5V 1.5-30MHz FM/AM/SSB
MRF475 12W 10dB 13.5V 1.5-30MHz FM/AM/SSB TO-220 BCE
MRF476 3W 15dB 13.5V 1.5-30MHz FM/AM/SSB TO-220 BCE
MRF477 40W 15dB 13.5V 1.5-30MHz FM/AM/SSB TO-220 BEC
MRF479 15W 10dB 13.5V 1.5-30MHz FM/AM/SSB TO-220
MRF485 15W 10dB 28V 1.5-30MHz WINTransceiver TO-220
MRF486 40W 15dB 28V 1.5-30MHz WINTransceiver TO-220
MRF496 40W 15dB 13.5V 1.5-30MHz WINTransceiver TO-220
MRF497 60W 10dB 13.5V 27-50MHz WINTransceiver TO-220 BEC
MRF517 0.75W 10dB 20V 1000MHz WINTransceiver TO-39
MRF607 1.75W 11.5dB 16V 175MHz WINTransceiver TO-39
MRF660 7W 5.4dB 12.5V 400-512MHz WINTransceiver TO-220
MS1226 30W 18dB 28V 30MHz FM/AM/SSB
MS1227 20W 15dB 12.5V 30MHz FM/AM/SSB
