查看: 5202|回复: 5
达林顿管的常用参数
发表于 2013-10-25 09:58:29 | 显示全部楼层 |阅读模式
    型号     Pcm[W]  Icm[A]  Vceo[V]  fT[MHz]  封装    用途   说明
  2N6035        40        4        60        -        TO-225        -        PNP        -
  2N6036        40        4        80        -        TO-225        -        PNP        -
  2N6038        40        4        60        -        TO-225        -        NPN        -
  2N6039        40        4        80        -        TO-225        -        NPN        -
  2N6040        75        8        60        -        TO-220        -        PNP
  2N6042        75        8        100        -        TO-220        -        PNP
  2N6043        75        8        60        -        TO-220        -        PNP
  2N6045        -                 -        -        TO-220        -        -
  2SB794        10        1.5        60        -        TO-126        -        PNP        NEC
  2SB795        10        1.5        80        -        TO-126        -        PNP        NEC
  2SC3075        -        -        -        -        TO-126        -        -        -
  2SC3294        -                 -        -        TO-202        -        -        -
  BD643         62.5        8        45        -        TO-220        -        NPN        -
  BD644         62.5        8        45        -        TO-220        -        PNP        -
  BD645         62.5        8        60        -        TO-220        -        NPN        -
  BD646         62.5        8        60        -        TO-220        -        PNP        -
  BD647         62.5        8        80        -        TO-220        -        NPN        -
  BD648         62.5        8        80        -        TO-220        -        PNP        -
  BD649         62.5        8        100        -        TO-220        -        NPN        -
  BD650         62.5        8        100        -        TO-220        -        PNP        -
  BD651         62.5        8        120        -        TO-220        -        NPN        -
  BD652         62.5        8        120        -        TO-220        -        PNP        -
  BD677         40        4        60        -        SOT-32        -        NPN        -
  BD678         40        4        60        -        SOT-32        -        PNP        -
  BD679         40        4        80        -        SOT-32        -        NPN        -
  BD680         40        4        80        -        SOT-32        -        PNP        -
  BD681         40        4        100        -        SOT-32        -        NPN        -
  BD682         40        4        100        -        SOT-32        -        PNP        -
  BDW42         85        15        100        -        TO-220        -        NPN
  BDW46         85        15        80        -        TO-220        -        NPN
  BDW47         85        15        100        -        TO-220        -        NPN
  BDW53         40        4        45        -        TO-220        -        NPN        -
  BDW53A        40        4        60        -        TO-220        -        NPN        -
  BDW53B        40        4        80        -        TO-220        -        NPN        -
  BDW53C        40        4        100        -        TO-220        -        NPN        -
  BDW53D        40        4        120        -        TO-220        -        NPN        -
  BDW63A        -                 -        -        TO-220        -        -
  BDX34         70        10        45        -        TO-220        -        PNP        -
  BDX34A        70        10        60        -        TO-220        -        PNP        -
  BDX34B        70        10        80        -        TO-220        -        PNP        -
  BDX34C        70        10        120        -        TO-220        -        PNP        -
  BDX53         60        8        45        -        TO-220        -        NPN
  BDX53A        60        8        60        -        TO-220        -        NPN
  BDX53B        60        8        80        -        TO-220        -        NPN
  BDX53C        60        8        100        -        TO-220        -        NPN
  BDX54         60        8        45        -        TO-220        -        PNP        -
  BDX54A        60        8        60        -        TO-220        -        PNP        -
  BDX54B        60        8        80        -        TO-220        -        PNP        -
  BDX54C        60        8        100        -        TO-220        -        PNP        -
  BF64           -                 -        -        TO-220        -                 -
  BF65           -                 -        -        TO-220        -                 -
  KSD5018        40        4        275        -        TO-220        -        NPN        -
  R3672          -                 -        -        TO-220        -        -
  R3673          -                 -        -        TO-220        -                 -
  R3674          -        -        -        -        TO-220        -        -
  2SB1214        -                 -        -        TO-251        -                 -
  2SB1418        -                 -        -        MT-4        -        -
  2SC5388        -                 -        -        TO-220        -        -
  2SD1197        -                 -        -        TO-3P        -        -
  2SD1748        -                 -        -        TO-251        -        -
  2SD1817        -                 -        -        TO-251        -                 -
  2SD2138        -                 -        -        MT-4        -                 -
  2SD2242        -                 -        -        MT-4        -        -
  2SD2265        -                 -        -        TO-252        -        -
  2SD2502        -                 -        -        TO-251        -                 -
  2SD2530        -                 -        -        MT-4        -                 -
  BDW83c         -                 -        -        TO-3P        -                 -
  RBL43P         -                 -        -        TO-3P        -                 -
  BU932R         -                 -        -        TO-3P        -                 -
  BU941          -                 -        -        TO-3P        -                 -
  TIP100        80        8        60        -        TO-220        NPN        b>1000        MOT
  TIP101        80        8        80        -        TO-220        NPN        b>1000        MOT
  TIP102        80        8        60        -        TO-220        NPN        b>1000        MOT
  TIP105        80        8        60        -        TO-220        PNP        B>200        MOT
  TIP106        80        8        80        -        TO-220
发表于 2014-10-21 19:26:24 | 显示全部楼层
谢谢分享
发表于 2015-2-6 02:17:09 | 显示全部楼层
都是很冷门少用的东西,难怪少人看~谢谢分享了
发表于 2015-4-27 10:31:05 | 显示全部楼层
多谢楼主分享,收藏了
发表于 2015-9-21 00:07:23 | 显示全部楼层
收下了,谢谢楼主分享
发表于 2015-10-16 09:48:52 | 显示全部楼层
GMT+8, 2025-4-30 19:52
