发表于 2013-4-17 07:20:30
I did some experiment. If you heat up a 1321 (thermocouple temperature sensor), the resistance goes up to 60ohm (at a pretty hot temperature).
Because of this, I think the software I wrote to drive a 1322 can be easily adopted to drive a 1321.
1322 heaters are used in Hakko 936 stations and 1321 heaters are used in Atten 936 stations.
