CPU:
Intel Pentium MMX 166 - 233 MHz 17w
Pentium II Klamath 233 - 300 MHz 43w
Pentium II 266 - 450 MHz 27w
Pentium III 450 - 1000 MHz 24---30w
Pentium III FC-PGA 600 - 800 MHz 21w
Pentium III FC-PGA 850 - 1000 MHz 35w
Pentium III Tualitin 1000 - 1300 MHz 38w
Celeron Socket 370 35w
赛扬 300 mhz 18W
赛扬 500 mhz 30w
赛扬Ⅱ 600 mhz 21w
赛扬Ⅱ 1.1ghz 40w
赛扬Ⅲtualatin 1ghz 27w
赛扬Ⅲtualatin 1.2ghz 29w
Celeron D 2.53 70w
Celeron D 330 2.66GHZ 74W
Celeron D 335J 2.8G LGA 775 84W
C4(willamette)1.7 62w
C4(willamette)1.8 65w
C4(northwood) 2.0 52w
C4(northwood) 2.1 54w
C4(northwood) 2.2 57w
C4(northwood) 2.4 61w
Intel Pentium 4 Socket 423
1.50Ghz 57.8---75W
1.60Ghz 61.0---89W
1.70Ghz 64.0---89W
1.80Ghz 66.7---89W
1.90Ghz 69.2---96W
2.00Ghz 71.8---96W
Intel Pentium 4 Socket 478 Willamette Northwood
1.50 Ghz 57.9W
1.60 Ghz 60.8W
1.70 Ghz 63.5W
1.80 Ghz 49??66.1W
1.90 Ghz 72.8W
?2.00 Ghz 52---75.3W
2.4 61w
2.4B 68w
2.4C 66W
2.66 59w
2.8C 67---70w
2.8E 85---89w
3.06 81---100w
3.0E 97w
3.2 82---103W
3.2EE 82---109W
Intel Pentium 4 Prescott 2000 -3000 Mhz 66--96w
其中 2.8G 84W
2.6G 78W
2.4G 73W
2.0G 66W
3.2G - 3.4G 100 ---131w
Intel Pentium 4 Extreme Edition (3200 Mhz) 92W
Intel Pentium 4 Extreme Edition (3400 Mhz) 103W
Intel Xeon Socket 604 87W
Intel Pentium M dothan 2.13g 99w
2.0g 96w
1.8g 95w
1.6g 95w
AMD K6 166 - 300 MHz 15W
AMD K6-2 233 - 550 MHz 18W
AMD K6-III 400 -450 MHz 18W
AMD Classic Athlon Slot A 500 - 750 MHz 35??45W
AMD Classic Athlon Slot A 800 - 850 MHz 45W
AMD Classic Athlon Slot A 900 - 950 MHz 55W
AMD Classic Athlon Slot A 1000 MHz 60W
AMD Athlon T-Bird 650 - 1000 MHz 42---49W
AMD Athlon T-Bird 1.1 GHz 56W
AMD Athlon T-Bird 1.2 GHz 59--66W
AMD Athlon T-Bird 1.3 GHz 63--68W
AMD Athlon T-Bird 1.4 GHz 65--72W
AMD Duron Spitfire 550 - 950 MHz 21--42W
其中 550 1.5v--21.1w
600 1.6v--27.4w
650 1.6v--29.4w
700 1.6v--31.4w
750 1.6v--33.4w
800 1.6v--35.4w
850 1.6v--37.4w
900 1.6v--39.5w
950 1.6v--41.5w
AMD Duron Morgan 900 - 1300 MHz 50??60W
900 1.75v 42.7w
950 1.75v 44.4w
1.0G 1.75v 46.1w
1.1G 1.75v 50.3w
AMD Duron Applebred 1400 -1800 MHz 57W
AMD Athlon XP Palomino 1500+ 1.4g 65--72w
1700+ 1.47g 57--64w
2100+ 1.73g 64--72w
AMD Athlon XP 1.75伏 2100+ 89.88w
AMD Athlon XP Thoroughbred 1600+ - 1900+ 53--66W
2000+ - 2100+ 62W
2200+ - 2700+ 68--76W
2800+ 333FSB 74W
AMD Athlon XP Barton 2500+ 1.833g 54??69w
2600+ 72W
3000+ 2.167g 58--74w
3200+ 77w
AMD AthlonXP 1500+ 1.33 GHz 60.0 w
1600+ 1.40 GHz 62.8 w
1700+ 1.47 GHz 64.0 w
1800+ 1.53 GHz 46--60w
1900+ 1.6g 48--61w
2000+ 1.667g 55--60w
2100+ 1.733g 56--64w
2200+ 1.8g 62--68w
2600+ 2.133g 62--68w
2800+ 2.25g 64--74w
AMD Athlon MP Palomino 1500+ - 2100+ 60---72w
AMD Athlon MP Barton 1g-1.2g 46---60w
AMD Athlon 64 (3000+ - 3400+) 67--89w
Socket754 2800+ 70--89W
Socket754 3000+ 73--89W
939 3000+ 67--75W
AMD Athlon 64 FX 89w
winchester 2.2g 118--162w
2.0g 118--158w
1.8g 118--155w
1.6g 117--149w
AMD Opteron (Single Processor) 85W
Sempron Socket462 2200+ 49W--62W
2300+ 59W
2400+ 61W
2500+ 64W
2600+ 49W--66W
2800+ 69W
Sempron Socket754 2600+ 62W
2800+ 65W
3100+ 62w??72W
显卡
早期S3 Savage3D RIVA 128、TNT、G200、Voodoo2等显卡功耗约为3??6W左右。到RIVA TNT2 、S3 Savage4、Voodoo3、G400、ATi Rage GL/VR这一代,功耗约为5??10W。随着GeForce 256、GeForce2、GeForce3、GeForce4系列和ATi RADEON、RADEON7500、8500、9000(9700)系列,显卡的功耗已达到了15??35W之间。专业级显卡的显存多且处理能力更为卓越,其功耗在35??60W之间。近期一些显卡的功耗特别是SLI的达到了150W??200W,甚至采用单独外接市电的办法。
32MB or Less AGP/PCI Basic Video 20-30W
oc版9550可参照9600/9600PRO/9600XT;S3 S3CE、6200 AGP 20-30W
ATI Radeon 7000/7500/8500 AGP/PCI 15--30 瓦
ATI Radeon 9000/9100/9200 AGP/PCI 15--35 瓦
ATI Radeon 9500/9600 20--56 瓦
ATI Radeon 9700/9800 40--60 瓦
ATI Radeon 9800XT 40--68 瓦
ATI Radeon X800 70---93 瓦
nVidia GeForce 3 Ti Series 30w
nVidia GeForce 4 MX Series 30w
Nvidia GeForce 4 Ti 4600 25--30w
nVidia GeForce 4 Ti Series 35w
nVidia GeForce FX 5200 30---65w
nVidia GeForce FX 5600 40--75w
nVidia GeForce FX 5800 80w
nVidia GeForce FX 5900 85w
nVidia GeForce FX 6800 (Regular/GT) 75---105w
nVidia GeForce FX 6800 Ultra 110w
6600 AGP 40W
6600 GT 50---75W
7800 以上 75---150W
内存:
128M PC66/PC100 SDRAM 7w
PC133 SDRAM 12w
256M DDR 6W ---15W
512M DDR 10 --25W
硬盘
开机初始化时 20-30W。
7200PRM 80G ---22W
7200PRM 160G---28W
光驱 CD-ROM 驱动器 15---20W
DVD-ROM 驱动器 15--25W
CD-RW 驱动器 15--25W
DVD/CDRW 组合驱动器 30w
DVD-RW / DVD+RW 驱动器 33W (COMBO 25W)
Zip 驱动器 10w
CD-ROM+DVD-ROM+CD-RW的总功率为71W左右。虽然三台设备同时工作的可能性很小,但是开机自检会涉及以上设备,因此考虑电源的承受功率时,必须考虑三个设备的最大值。
主板(不含CPU、内存) 20-30W (集成显卡再加多5-10W)
要准确的推断主板的耗电是非常困难的。通常主板上最耗电的是南、北桥芯片,像SiS公司的某些主芯片只有一块。通常非整合主板的耗电量不超过20W,整合主板的耗电量不超过25W。
但有关资料介绍:
I875+ICH5R-------66W
865PE+ICH5-------61W
I848+ICH5------- 60W
845E+ICH4 -------43W
845GL+ICH4-------46W
NFORCE2U400+MCP-T-------60W
VIA KT600+VT8237 -------57W
VIA KT400A+8235-------56W
PCI SCSI控制卡 20??25W
PCI 56K内置式调制解调器(外置式单独供电不考虑) 4-------8w
PCI 网卡 4-------6W
PCI 声卡(AC'97声卡3W,创新顶级声卡10W) 3-------10W
其它附加PCI卡 5w
软盘驱动器 5w
键盘或鼠标 1.3-------3w
CPU风扇 3-------7w
机箱风扇 1.5-------3W
USB摄影头 2.5w
冷阴极管 3w
内置6合1存储器 10w
外置设备的系统检查
USB 1.1/2.0 设备 2.5W-------5
IEEE-1394 带电源设备 8
显示器
17CRT 80W
19CRT 105W
15LCD 35W
17LCD 44W
19LCD 50W
二、对电脑电源功率的选择和估算
掌握了电脑各配件的功耗,选择电源功率就有了基础。但是选择确定电源功率之前,首先要考虑的是:
一是明确电源需求目标。是为了仅仅满足当前供电的经济需求,还是要同时考虑今后添加设备、升级的预留需求。同时考虑今后添加设备、升级的预留需求的,必须把今后添加设备的功耗计算在内。
二是选择电源时,必须考虑电源供电接口能够满足主板上全部内置接口的需要,以及显卡接口的需要,特别是当前主流的SATA接口为4个(有些高档主板有6??8个SATA接口)、PCIE16的6PIN接口要有2个等,尽量不要另买转接卡线。
三是考虑电源的静音效果。许多电源厂家不介绍其产品的满载噪音大小,非不能也,乃不愿也。TT电源之所以为人们所称道,看看厂家网站就知道了,各项产品技术指标非常明确,包括噪音指标和各种接口规格,一目了然。本人浏览了众多厂家网站,都没有TT作的好,由此可以看出其营销管理水平的高低。
四是电源规范尽量选用ATX 12V 2.2规范的,它对电源整体转换效率(80%以上)和接口作了规定,同时具备向下的兼容性。
其次在作出上述选择之后,我们来进行电源功率的选择和估算。方法如下:
1、根据电脑配件的功耗计算需要的电源额定功率。
根据电工学原理,电源供电功耗*电源整体转换效率=电源实际输出功率(即电脑配件功耗之和)。实际的计算方法是:电脑配件功耗之和/电源整体转换效率=电源额定功率。其中,属于ATX 12V 2.0 规范及以下版本的电源,其电源整体转换效率为70%,属于ATX 12V 2.2 规范版本的电源,其电源整体转换效率为80%。如果我们要更精确地计算,还应当查看每种电源出厂时说明的转换效率。
2、根据电脑各配件功耗最大值之和直接相加,确定电源的额定功率。这一简单易行的方法忽略了两个因素,一是没有考虑电源整体转换效率,如果考虑这一因素,对电源的额定功率相应增加,将回归到第一种方法。二是电器设备在厂家设计时,都会对出厂的额定功率打上一定的保险系数。我们看到诸多的电源测评中,最大值与额定功率的差额就是电源留有保险系数的结果。根据经验,这一保险系数一般为20%??50%。如果想尽可能地挖掘电源潜力,我们选择电源的额定功率时,可以适当减少。当然,电源在持续供电中的危险性也将增加。恰好这两个因素一增一减,本人把它们同时忽略。
3、最简单的经验估计法。看了前文电脑配件功耗资料,可以说是沧海茫茫,但是咱家“只需一瓢饮”。怎么办?可以归类估计,即耗电量大的配件单独计算,耗电量小的归类估计。方法是:CPU功耗+显卡功耗+硬盘功耗+主板一揽子功耗=电源功率。
其中,CPU:AMD的75W,INTEL的100W;显卡:一般50W,SLI的150W;光驱、硬盘,每个30W;主板等一揽子60W(包括:主板、PCI网卡、声卡、软驱、键盘、鼠标、 CPU风扇、机箱风扇、USB摄影头等)。当然,这个方法是最不科学的,却是有一定经验者的最简单的方法!各位DIY们,可以根据具体情况和自己的经验对CPU功耗作出适当的调整。
例如:装配时下流行的SLI级别的AMD的电脑,需要电源功率:CPU 75W,显卡150W,主板等60W,硬盘2个光驱1个计90W,合计375W,符合INTEL电源规范 >350W的要求;如果是单显卡的,减少100W,合计275W,符合INTEL电源规范 P4 级别的要求;这意味着,我们把选择电源的复杂问题简单化了,进退取舍之间,是不是与时下电源规范要求大体相适应呢 |
