发表于 2013-2-11 04:44:11
For those who want to learn about JLH1969 or JLH1969M, you can google Williamson tube amplifier - the first HI-FI amp ever.
You will see a lot of similarity between Williamson and JLH1969: the JLH1969 is simply a current-driven version of Williamson, and the JLH1969M, using voltage driven output devices, are truer to Williamson than JLH1969 (using current-driven output devices).
Nelson Pass, a few years after I introduced JLH1969M, introduced PLH, which is essentially the JLH1969M without its input stage:
To me, JLH1969M is one of those first-watt amplifiers: you can configure it to run in Class A for the 1watt or less, and then transition smoothly into Class B for higher output.
For 1w rms @ 8ohm, that means idle current of 500ma. That can be easily done with TO220 devices in JLH1969M, and piece of cake for TO3P devices.
对于那些想了解JLH1969或JLH1969M的人来说,你可以谷歌Williamson管放大器 - 有史以来第一个HI-FI放大器。
威廉姆森和JLH1969之间会有很多相似之处:JLH1969仅仅是威廉姆森的电流驱动版本,使用电压驱动输出设备的JLH1969M对于威廉姆森来说比JLH1969更真实(使用电流驱动输出设备)。
在我介绍JLH1969M几年之后,Nelson Pass引入了PLH,它基本上是没有输入阶段的JLH1969M:
对我而言,JLH1969M是其中一款功耗最高的放大器:您可以将其配置为在Class A中运行1瓦或更低的功率,然后平稳过渡到B类以获得更高的输出。
对于1w rms @ 8ohm,这意味着500ma的空载电流。在JLH1969M中使用TO220器件可以轻松完成,而TO3P器件则可以轻松完成。
