ICD3Err0045: You must connect to a target device to use MPLAB ICD3.
ICD3Err0045: 您必须连接到目标设备才能使用 MPLAB ICD3
ICD3Err0035: Failed to get Device ID. If you experience persistent problems communicating, the ICD3 test interface can be used to help diagnose the problem.
ICD3Err0035: 无法获取设备ID。如果您遇到持续存在的通信问题,ICD3测试接口可用于帮助诊断问题
通过6芯电缆线连AC164113
Test interface PGC clock line write succeeded
测试接口PGC时钟线写入成功
Test interface PGD data line write succeeded
测试接口PGD数据线写入成功
Test interface PGC clock line read succeeded
测试接口PGC时钟线读取成功
Test interface PGD data line read succeeded
测试接口PGD数据线读取成功
Test interface LVP control line test succeeded
测试接口LVP控制线测试成功
Test interface MCLR level test succeeded
测试接口MCLR水平(拉低电压?)测试成功
测试通过,就是不能烧写 |
