查看: 2982|回复: 3
fu50单端放大器参数选择
发表于 2022-3-19 10:08:00 | 显示全部楼层 |阅读模式
洋人设计,实做测试过
曲线图
曲线图
GU50 in parallel SE
HT 450V
Screens 300V
-46 volts bias @ 60mA for 27W dissipation
Sine wave test 200mV 1K
8W very clean (10% distortion)
11W on the visual onset of clipping (CRO)
Full power 18W
What was happening though was the screen supply was dropping to 275 volts under load. The regulator is meant to output 250mA but was giving up with only a 25mA load so I need to investigate that further.
As an experiment (valves are cheap) I connected the un-regulated supply to the screens, (314V under load) and achieved an output of 25Ws with the screens only dropping a small amount.
The 3K OT load produce slightly less power than the 2K3 which tends to agree with the consensus of a 5K load
Sound testing with guitar, it needs a tone control. Clean is very clear and defined but  as the volume increases it sounds too hi-fi like.
Anyway, just a learning experience and practice driving my test tools (new distortion meter)
 楼主| 发表于 2022-3-19 10:09:51 | 显示全部楼层
A single GU50 is happy to work with
Anode 300v (130mA idle)
G2 250v (3.5 mA idle - 20mA full roar)
G1 -24v
Load 2k
Signal for max output 17v AC
Output Power 18W
Distorsion 10%
发表于 2022-3-19 13:40:07 | 显示全部楼层
上边是并管单端,下边是单管单端。都是标准接法。
发表于 2022-3-28 14:42:01 | 显示全部楼层
英文还给老师了
GMT+8, 2025-4-29 12:12
