查看: 1976|回复: 0
【分享】51单片机读写25Q80测试程序
发表于 2020-11-14 23:28:58 | 显示全部楼层 |阅读模式
#include <reg52.h>
#include <intrins.h>
unsigned long Addre24;    //24位的Flash地址
sbit CS          = P1^0; //选通
sbit SCLK        = P1^1; //时钟
sbit DIO         = P1^2;  //输入
sbit DO          = P1^3; //输出
void Send_OneByte(unsigned char DATA8) //从SPI发8位数
{                                        //上升沿写入
   unsigned char x;
   for (x=0;x<8;x++)
  if(DATA8&0x80)
   DIO=1;
  else
  DIO=0;
  DATA8=DATA8<<1;
  SCLK=0;
  SCLK=1;
unsigned char Read_OneByte(void)     //从SPI收8位数
   {                                   //下降沿输出
   unsigned char DATA8;
   unsigned char x;
   SCLK=1;
   for (x=0;x<8;x++)
  SCLK=1;
  SCLK=0;
  DATA8=(DATA8<<1)|DO;
   return (DATA8);
//*************** 写允许 ****************************  OK
void WriteEnable  (void)
   CS=0;
   Send_OneByte(0x06);
   CS=1;
//*************** 写禁止 **************************** OK
void WriteDisable (void)
   CS=0;
   Send_OneByte(0x04);
   CS=1;
//***************判BUSY********************************
unsigned char W25X_BUSY_OrNot (void) //在读和写之前得先判断FLASH是否BUSY
   {                                   //BUSY的原因是擦除,或是连续读写
   unsigned char k;                  // 如果没有以上方式,不必判定可以写读
                                      //   PCA0CPH2 = 0x00;
   SCLK=1;
   _nop_();
   CS=0;
   Send_OneByte(0x05);  //读状态寄存器
   k=Read_OneByte();  //读一个字节
   k=k&0x01;
   CS=1;_nop_();
   SCLK=1;
   if(k)return (0x01);
   else return (0x00);
void W25X_Flash_Byte_Write(unsigned long Addre24,unsigned char dat)
   while(W25X_BUSY_OrNot ()  );  //判BUSY 等到Flash闲才能操作
   WriteEnable();                //写允许
                                 //把地址拆开来
   CS=0;
   Send_OneByte(0x02);         //命令
   Send_OneByte(Addre24>>16);
   Send_OneByte(Addre24>>8);
   Send_OneByte(Addre24);
   Send_OneByte(dat);
   CS=1;
   WriteDisable ();
   }  //写FLASH结束
unsigned char W25X_Flash_Byte_Read (unsigned long Addre24)  //从Flash里读出小于256字节数
unsigned char temp;
   while(W25X_BUSY_OrNot ());  //判BUSY
   WriteEnable();
   CS=0;
   Send_OneByte(0x03);//命令读
   temp=Read_OneByte();
   CS=1;
   WriteDisable ();
   return temp;
//**************片擦除 (MAX_80S)****************** OK
void W25X_ChipErase(void)
  SCLK=1;
  CS=0;
  Send_OneByte(0xc7);//整片擦除命令
  CS=1;              //从CS=1时开始执行擦除
//*************** 4K扇擦除************************ OK
void W25X_SectorErase(unsigned long Addre24) //擦除资料图示的4KB空间
   unsigned char Addre3;
   unsigned char Addre2;
   unsigned char Addre1;
   Addre1=Addre24;
   Addre24=Addre24>>8;
   Addre2=Addre24;
   Addre24=Addre24>>8;
   Addre3=Addre24;   //把地址拆开来
   SCLK=1;
   CS=0;
   Send_OneByte(0x20);//整扇擦除命令
   Send_OneByte(Addre3);
   Send_OneByte(Addre2);
   Send_OneByte(Addre1);
   CS=1;
                     //64K页/块擦除
void W25X_BlockErase(unsigned long Addre24) //擦除资料图示的64KB空间
   Addre1=Addre24;
   Addre24=Addre24>>8;
   Addre2=Addre24;
   Addre24=Addre24>>8;
   SCLK=1;
   CS=0;
   Send_OneByte(0xd8);//整扇擦除命令
   CS=1;
void main()
    //W25X_ChipErase();              //片擦除
    W25X_SectorErase(0);                  //4K擦除
    //W25X_BlockErase (Addre24);        //64K块擦除
        W25X_Flash_Byte_Write(0,0x01);  //写入存存储据
while(1)
  P0=W25X_Flash_Byte_Read (0);           //读出存储数据
GMT+8, 2025-4-28 09:06
