#include<reg51.h>
#include<absacc.h>
#include<intrins.h>
#include<string.h>
#define uchar unsigned char
#define uint unsigned int
//引脚连接定义
sbit cs =P1^0;//片选
sbit reset =P1^1;//复位
sbit rs =P1^2;//地址/数据切换
sbit sda =P1^3;// SDI MOSI
sbit scl =P1^4;//时钟
//SDO引脚可以不连接
uchar bdata bitdata;
sbit bit7=bitdata^7;
sbit bit6=bitdata^6;
sbit bit5=bitdata^5;
sbit bit4=bitdata^4;
sbit bit3=bitdata^3;
sbit bit2=bitdata^2;
sbit bit1=bitdata^1;
sbit bit0=bitdata^0;
void delay(uint t);
void delay(uint time)
uint i,j;
for(i=0;i<time;i++)
for(j=0;j<2500;j++);
void write_command(uchar c)
cs=0;
rs=0;
bitdata=c;
sda=bit7;scl=0;scl=1;
sda=bit6;scl=0;scl=1;
sda=bit5;scl=0;scl=1;
sda=bit4;scl=0;scl=1;
sda=bit3;scl=0;scl=1;
sda=bit2;scl=0;scl=1;
sda=bit1;scl=0;scl=1;
sda=bit0;scl=0;scl=1;
cs=1;
void write_data(uchar d)
cs=0;
rs=1;
bitdata=d;
cs=1;
void wr_com16(unsigned char i,unsigned char j)
cs=0;
rs=1;
bitdata=i;
cs=1;
cs=0;
rs=1;
bitdata=j;
cs=1;
void lcd_initial()
reset=0;
delay(100);
reset=1;
delay(100);
//2.2inch TM2.2-G2.2 Init 20171020
write_command(0x11);
write_data(0x00);
write_command(0xCF);
write_data(0X00);
write_data(0XC1);
write_data(0X30);
write_command(0xED);
write_data(0X64);
write_data(0X03);
write_data(0X12);
write_data(0X81);
write_command(0xE8);
write_data(0X85);
write_data(0X11);
write_data(0X78);
write_command(0xF6);
write_data(0X01);
write_data(0X30);
write_data(0X00);
write_command(0xCB);
write_data(0X39);
write_data(0X2C);
write_data(0X00);
write_data(0X34);
write_data(0X05);
write_command(0xF7);
write_data(0X20);
write_command(0xEA);
write_data(0X00);
write_data(0X00);
write_command(0xC0);
write_data(0X20);
write_command(0xC1);
write_data(0X11);
write_command(0xC5);
write_data(0X31);
write_data(0X3C);
write_command(0xC7);
write_data(0XA9);
write_command(0x3A);
write_data(0X55);
write_command(0x36);
write_data(0x48);//竖屏参数
write_command(0xB1);
write_data(0X00);
write_data(0X18);
write_command(0xB4);
write_data(0X00);
write_data(0X00);
write_command(0xF2);
write_data(0X00);
write_command(0x26);
write_data(0X01);
write_command(0xE0);
write_data(0X0F);
write_data(0X17);
write_data(0X14);
write_data(0X09);
write_data(0X0C);
write_data(0X06);
write_data(0X43);
write_data(0X75);
write_data(0X36);
write_data(0X08);
write_data(0X13);
write_data(0X05);
write_data(0X10);
write_data(0X0B);
write_data(0X08);
write_command(0xE1);
write_data(0X00);
write_data(0X1F);
write_data(0X23);
write_data(0X03);
write_data(0X0E);
write_data(0X04);
write_data(0X39);
write_data(0X25);
write_data(0X4D);
write_data(0X06);
write_data(0X0D);
write_data(0X0B);
write_data(0X33);
write_data(0X37);
write_data(0X0F);
write_command(0x29);
void addset(unsigned int x,unsigned int y)
write_command(0x2a);
wr_com16(x>>8,x);
write_command(0x2b);
wr_com16(y>>8,y);
write_command(0x2c);
void dsp_single_colour(DH,DL)
unsigned int i,j;
addset(0,0);
for (i=0;i<320;i++)
for (j=0;j<240;j++)
wr_com16(DH,DL);
main()
lcd_initial();
dsp_single_colour(0x84,0x10);//灰色
dsp_single_colour(0xff,0xff);//白色
dsp_single_colour(0x00,0x00);//黑色
dsp_single_colour(0xf8,0x00);//红色
dsp_single_colour(0x07,0xe0);//绿色
dsp_single_colour(0x00,0x1f);//蓝色
while(1) ;
