#include<reg51.h>
#include<intrins.h>
#include<stdlib.h>
typedef unsigned int u16;
typedef unsigned char u8;
sbit SER=P2^4;
sbit up=P2^2; //上
sbit down=P2^1;//下
sbit lt=P2^3; //左
sbit rt=P2^0; //右
u8 code Hc595_Coordx[]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};
u8 code Hc595_Coordy[]={0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01};
u8 foodx;
u8 foody;
u8 snake_x[20]={0};
u8 snake_y[20]={0};
u8 length;
u8 direction;
void initSnake();
void delay(u16 i);
void Hc595SendByte(u8 dat);
void move();
void Keypros();
void creatFood();
void snake_Grow(void);
void drawsnake();
void initSnake()
snake_x[0]=0;
snake_y[0]=0;
length=1;
direction=2;
void delay(u16 i)
while(i--);
void move()
u8 len = length- 1;
for(len; len > 0; len--)
snake_x[len] = snake_x[len - 1];
snake_y[len] = snake_y[len - 1]; //一直到蛇头
switch(direction)
case 1:
snake_y[0]--;
break;
case 2:
snake_y[0]++; //再利用蛇头转变方向
break;
case 3:
snake_x[0]--;
break;
case 4:
snake_x[0]++;
break;
default:
break;
//贪吃蛇的上下左右行动控制
void Keypros()
if(up==0)
delay(1000); //消抖处理
if(up==0)
if(direction==3|direction==4)
direction=1; //在地址1内写入数据num
while(!up);
if(down==0)
delay(1000); //消抖处理
if(down==0)
{ if(direction==3|direction==4)
direction=2;
while(!down);
if(lt==0)
delay(100); //消抖处理
if(lt==0)
if(direction==1|direction==2)
direction=3;
while(!lt);
if(rt==0)
delay(1000); //消抖处理
if(rt==0)
direction=4;
while(!rt);
void creatFood() //随机创造食物
u8 i;
foodx=rand()%8;
foody=rand()%8;
for(i=0; i<length; i++)
if((foodx==snake_x)&&(foody==snake_y)) //如果食物与蛇的身体重叠,要重新创建
creatFood();
if(snake_x[0] == foodx && snake_y[0] == foody)
creatFood();
snake_x[length] = snake_x[length - 1];
snake_y[length] = snake_y[length - 1];
length++;
void drawsnake() //点亮蛇和食物
u8 i;
for(i=0;i<length;i++)
P1=Hc595_Coordy[snake_y];
P0=Hc595_Coordx[snake_x];
delay(20);
P0=0xff;
P1=Hc595_Coordy[foody];
P0=Hc595_Coordx[foodx];
delay(20);
P0=0xff;
void JudgeDeath(void)
u8 i;
// 判断蛇撞墙死亡
if((snake_x[0]>7)||(snake_y[0]>7))
Hc595SendByte(0x00);
while(1);
// 判断蛇撞到自己身体死亡
for(i=4; i<length; i++)
if((snake_x[0]==snake_x)&&(snake_y[0]==snake_y))
P0=0xFF;
while(1);
void Timer0Init()
TMOD|=0X01;//选择为定时器0模式,工作方式1,仅用TR0打开启动。
TH0=0XD8; //给定时器赋初值,定时10ms
TL0=0XF0;
ET0=1;//打开定时器0中断允许
EA=1;//打开总中断
TR0=1;//打开定时器
void main()
Timer0Init();
initSnake();
while(1)
drawsnake();
JudgeDeath();
snake_Grow();
Keypros();
void Timer0() interrupt 1
static u16 i;
TL0=0XF0;
i++;
if(i==50)
i=0;
move();
https://www.bilibili.com/video/BV1mt4y197HQ/ |
