很简单的等精度频率计,几经改进,增加了功能,又减少了功能,改了线路,换了器件,折腾好久,最后还是归到极简。好用,高精度,准确,这才是最重要的。高基准时钟,不准确也是没用,所以,回归到最容易得到的10M温补晶振上。显示重做了LED显示,而没用现成的模块。
开源网址:https://github.com/elezen/Cymomer
这里也贴个程序和电路图:
- #define FREQ 10000000L
- #define NORMAL 100
- #define FAST 10
- #define KEYDLY 50
- #define KEYLONG 500
- //#define FREQ 40499753L
- #include <mcs51/at89x52.h>
- #define CLR P3_7
- #define GATECTL P3_6
- #define GATE P3_3
- #define KEY P1_0
- #define KEY2 P1_1
- #define false 0
- #define true 1
- __code unsigned char LedSegs[]={3, 159, 37, 13, 153, 73, 65, 31, 1, 9, 17, 193, 99, 133, 97, 113};
- __code unsigned char LedDigit[]={0x1,0x2,0x4,0x8,0x10,0x20,0x40,0x80};
- __idata char leds[8];
- char led_i,num_i=0;
- __bit ledReady,overflow=false,gatelost=false;
- char led_d;
- unsigned char msTick=0,gateDelay=0,speed=NORMAL,keydly=KEYDLY;
- unsigned int delay=0;
- unsigned long mainFreq=FREQ;
- __code char cymomer[] = {0x63,0x89,0x55,0xc5,0x55,0x21,0xf5,0xff};
- __code char counter[]={0x63,0xc5,0xc7,0xd5,0xe1,0x21,0xf5,0xff};
- __code char freq[] = {0x71,0xf5,0x21,0x19,0xff,0xff,0xff,0xff};
- __code char fast[] = {0x43,0x11,0xe1,0x61,0xff,0x2, 0x9f,0x4b};
- __code char normal[] ={0x43,0x11,0xe1,0x61,0xff,0x9e, 0x3,0x4b};
- typedef union{
- unsigned long l;
- struct{char b0,b1,b2,b3;};
- } TmLong;
- TmLong inCnt,freqCnt;
- unsigned long incount,freqcount;
- void counter0() __interrupt 1{
- ++inCnt.b3;
- void counter1() __interrupt 3{
- ++freqCnt.b3;
- void serialPort() __interrupt 4{
- if(RI)RI=0;
- if(TI){
- TI=0;
- if(!ledReady){
- SBUF=leds[led_i];
- P3_2=0;
- ledReady=1;
- }else{
- P3_2=1;
- void timer2(void) __interrupt 5{
- TF2=0;
- ledReady=0;
- if(++led_i>7)led_i=0;
- SBUF=LedDigit[led_i];
- if(--msTick==0){
- msTick=speed;
- if(gateDelay>0)gateDelay--;
- void putstr(char *s){
- unsigned char i=7;
- do{
- leds[i]=*s;
- s++;
- }while(i--);
- void putlong(unsigned long a){
- char i,c;
- __idata unsigned char buf[8];
- for(i=0;i<8;i++){
- if(a!=0||i==0){
- c=LedSegs[a%10];
- if(i==3||i==6)c&=0xfe;
- buf[i]=c;
- a/=10;
- }else{
- buf[i]=0xff;
- if(a>0)overflow=true;
- if(overflow)buf[7]&=0xfe;
- if(gatelost)buf[0]&=0xfe;
- for(i=0;i<8;i++)leds[i]=buf[i];
- unsigned long getCount(){
- inCnt.b0=P0;
- inCnt.b1=TL0;
- inCnt.b2=TH0;
- return inCnt.l;
- unsigned long getFreq(){
- if(freqcount==0)return 0;
- return (unsigned long)(((unsigned long long)incount)*mainFreq/freqcount);
- void reset(){
- GATECTL=0;
- TR0=0;TR1=0;
- inCnt.b0=P0;
- inCnt.b1=TL0;
- inCnt.b2=TH0;
- incount=inCnt.l;
- inCnt.b3=0;
- freqCnt.b0=P2;
- freqCnt.b1=TL1;
- freqCnt.b2=TH1;
- freqcount=freqCnt.l;
- freqCnt.b3=0;
- CLR=1;
- TH0=TL0=TH1=TL1=0;
- overflow=false;
- CLR=0;
- TR0=1;TR1=1;
- GATECTL=1;
- __bit longdown=false;
- unsigned char readKey(){
- static __bit longdown=false;
- static unsigned int keylong=KEYLONG;
- unsigned char k=0,key=0;
- static unsigned char gotkey=0;
- if(!KEY)key=1;if(!KEY2)key=2;
- if(key!=0){
- gotkey=key;
- if(keydly>0)keydly--;
- if(keylong>0)keylong--;
- else{
- if(!longdown){
- longdown=true;
- k=key+2;
- }else{
- if(keydly==0 && !longdown)k=gotkey;
- keydly=KEYDLY;
- keylong=KEYLONG;
- longdown=false;
- return k;
- enum{Freq,Counter} mode=Freq;
- void setmode(){
- switch(readKey()){
- case 1: //+
- switch(mode){
- case Freq:
- speed=NORMAL;
- putstr(normal);
- reset();
- gateDelay=16;
- delay=1000;
- break;
- case Counter:
- GATECTL=!GATECTL;
- break;
- break;
- case 2: //-
- switch(mode){
- case Freq:
- speed=FAST;
- putstr(fast);
- reset();
- gateDelay=16;
- delay=1000;
- break;
- case Counter:
- reset();
- break;
- break;
- case 3: //Freq<->counter
- case 4:
- if(mode!=Freq){
- mode=Freq;
- putstr(freq);
- }else{
- mode=Counter;
- putstr(counter);
- reset();
- delay=1000;
- break;
- void main(void){
- PT0=1;PT1=1;
- PT2=1;
- SCON=0;
- REN=0;
- ES=1;
- GATECTL=0;
- CLR=1;
- TMOD=0x55;
- TR0=0;TR1=0;ET0=1;ET1=1;
- TH0=0;
- TL0=0;
- TH1=0;
- TL1=0;
- RCAP2H=0xFD; //10M 1/1000s
- RCAP2L=0xBE;
- T2CON=0;
- T2MOD=0;
- TR2=1;
- ET2=1;
- EA=1;
- putstr(cymomer);
- delay=1000;
- while(1){
- PCON|=1;
- setmode();
- if(delay>0){delay--;continue;}
- switch(mode){
- case Freq:
- if(!GATE&&!GATECTL||gateDelay==0){
- gatelost=gateDelay==0;
- reset();
- putlong(getFreq());
- gateDelay=16;
- }else if(gateDelay==5){
- GATECTL=0;
- break;
- case Counter:
- putlong(getCount());
- delay=50;
- break;
复制代码
编译用SDCC,51 small,加入 small 的 longlong.lib 库。
