查看: 7432|回复: 15
我想高手看一下下面这些是不是金封运放。
发表于 2019-3-9 12:33:58 | 显示全部楼层 |阅读模式
我不会发图,我想样高手看看这些金封管上面的型号是不是运放块,能不能用在音响上【TA7034M】【TA7506M】【AD584KH】【H8524LF398AH】我在这里多谢了。
发表于 2019-3-9 12:44:11 | 显示全部楼层
查询不到资料吗?
发表于 2019-3-9 13:58:31 | 显示全部楼层
TAxxxx只是一般的运放,用于音响性能一般,AD584是基准电源,好东西,最后一个不知道。
发表于 2019-3-9 14:56:23 | 显示全部楼层
发图片看呀
 楼主| 发表于 2019-3-9 17:58:32 | 显示全部楼层
我不会发图片,年纪大了,
 楼主| 发表于 2019-3-9 18:00:10 | 显示全部楼层
外形和3DG12一样
发表于 2019-3-9 18:41:15 | 显示全部楼层
The LF198/LF298/LF398 are monolithic sample-and-hold circuits which utilize BI-FET technology to obtain ultra-high dc accuracy with fast acquisition of signal and low droop rate. Operating as a unity gain follower, dc gain accuracy is 0.002% typical and acquisition time is as low 0.01%. A bipolar input stage is used to achieve low offset voltage and wide bandwidth. Input offset adjust is accomplished with a single pin, and does not degrade input offset drift. The wide bandwidth allows the to be included inside the feedback loop of 1 MHz op amps without having stability problems. Input impedance of 1010 allows high source impedances to be used without degrading accuracy. P-channel junction FET's are combined with bipolar devices in the output amplifier to give droop rates as low as 5 mV/min with 1 μF hold capacitor. The JFET's have much lower noise than MOS devices used in previous designs and do not exhibit high temperature instabilities. The overall design guarantees no feed-through from input to output in the hold mode, even for input signals equal to the supply voltages.
http://www.ti.com/lit/ds/symlink/lf198-n.pdf
发表于 2019-3-9 18:42:55 | 显示全部楼层
所说的金封是指的金属外壳封装,外形和3DG12一样就是金属封装。能不能用在音响没试过。
发表于 2019-3-9 18:45:09 | 显示全部楼层
【H8524LF398AH】会不会是LF398AH ? 猜的噢
 楼主| 发表于 2019-3-9 19:20:58 | 显示全部楼层
会不会是LF398AH 。可能是
发表于 2019-3-9 19:23:09 | 显示全部楼层
我也认为是LF398AH ,这个是单运放。
发表于 2019-3-9 21:48:50 | 显示全部楼层
金封运放不一定有多好听大多数都不是用于音频的只是人们的炒作
发表于 2019-3-10 12:52:59 | 显示全部楼层
7#的网上翻译;
LF198/Lf298/Lf398是单片采样保持电路,利用BI-FET技术,通过快速采集信号和低下垂率获得超高精度。
作为单位增益跟随器工作,增益精度典型值为0.002%,采集时间低至0.01%。双极性输入级用于实现低失调
电压和宽带宽。输入失调调整由单个引脚完成,不会降低输入失调漂移。宽带宽允许将其包含在1MHZ
运算放大器的反馈环路内,而不会出现稳定性问题。输入阻抗1010允许使用高源阻抗而不降低精度。P沟道结
FET与输出放大器中的双极性器件相结合,通过1uF保持电容提俱低至5mV/min的下垂率。
JFET的MOS的噪声比先前设计中使用的MOS器件低得多,并且不会出现高温不稳实性。整体设计保证在保持模
式下无输入到输出的馈通,即使输入信号等于电源电压也是如此。
 楼主| 发表于 2019-3-12 08:11:34 | 显示全部楼层
多谢了
多谢了
多谢了
发表于 2019-3-20 03:18:14 | 显示全部楼层
就算是运放都不是所有的都适合用在音频上面。
GMT+8, 2025-5-2 14:08
