发表于 2019-2-17 17:20:10
unsigned char read_snr() //读取当前频道信噪比(SNR)函数
unsigned char temp;
temp=read_reg_bk1088e(0x09);
temp=temp&0x7f;
return temp;
可以直接简化为
return read_reg_bk1088e(0x09) & 0x7f;
bit read_st() //读取当前立体声状态函数
unsigned int temp;
bit st;
return read_reg_bk1088e(0x0a) & 0x0180 ;
temp=temp&0x0180;
if(temp==0x0180)st=1;
else st=0;
return st;
可以直接简化为
return (read_reg_bk1088e(0x0a) &0x0180) ==0x0180;
