发表于 2011-5-29 23:49:15
http://www.alldatasheet.com/data ... IBA/TMP87CM41F.html
it looks to be a fairly high-end chip: nested interrupts, multiple timers, dedicated pwm channels, single / continuous memory space and high current-capable drives.
it is a cisc chip so it should be fairly fast.
别在这上面费劲了,日系的单片机,通用性不强,多用在家电上.还是学51去吧.
Renesas (which is the successor to mostly Toshiba/NEC's mcu business) is by far the largest mcu manufacturer in the world. they are a multitude bigger than Microchip (and huge vs. atmel).
the likely issue here is that the development tools will be quite expensive. |
