发表于 2012-3-22 15:21:24
补充一下 LTSPICE 的 模型:
Edit the file standard.jft and add the following info at the end :
.model J310 NJF(Beta=3.384m Rd=1 Rs=1 Lambda=17m Vto=-3.409
Is=193.9f Cgd=6.2p Pb=1 Fc=.5 Cgs=6.2p Kf=46.34E-18 Af=1)
.model BF245A NJF(VTO=-2 BETA=0.9M LAMBDA=6m RD=2.21. + RS=1.99
IS=26.3F PB=1 FC=.5 CGS=2.12P CGD=2.52P)
.model 2N7000 NMOS( LEVEL=3 RS=0.205 NSUB=1.0E15 DELTA=0.1 KAPPA=0.0506
TPG=1 CGDO=3.1716E-9 RD=0.239 VTO=1.000 VMAX=1.0E7 ETA=0.0223089 NFS=6.6E10
TOX=1.0E-7 LD=1.698E-9 UO=862.425 XJ=6.4666E-7 THETA=1.0E-5 CGSO=9.09E-9
L=2.5E-6 W=0.8E-2)
http://hq.scene.ro/blog/read/ltspice-components/
Here're the 2n7000 models you posted, here on s.e.d., IIRC.
I had to modify some of them to run on Intusoft's spice.
Anasoft-1:
..SUBCKT 2N7000/PLP_XN _ssi_pin0_1 _ssi_pin1_2 _ssi_pin2_3
Cgs 2 3 12.3E-12
V_ssi_pin2 _ssi_pin2_3 3 0
V_ssi_pin1 _ssi_pin1_2 2 0
V_ssi_pin0 _ssi_pin0_1 1 0
Cgd1 2 4 27.4E-12
Cgd2 1 4 6E-12
M1 1 2 3 3 MOST1
M2 4 2 1 3 MOST2
D1 3 1 Dbody
..MODEL MOST1 NMOS(Level=3 Kp=20.78u W=9.7m L=2u Rs=20m Vto=2 Rd=1.186)
..MODEL MOST2 NMOS(VTO=-4.73 Kp=20.78u W=9.7m L=2u Rs=20m)
..MODEL Dbody D(Is=125f N=1.023 Rs=1.281 Ikf=18.01 Cjo=46.3p M=.3423
+ Vj=.4519 Bv=60 Ibv=10u Tt=161.6n)
..ENDS
Anasoft-2:
..SUBCKT 2N7000_XN _ssi_pin0_3 _ssi_pin1_4 _ssi_pin2_5
* Nodes D G S
V_ssi_pin2 _ssi_pin2_5 5 0
V_ssi_pin1 _ssi_pin1_4 4 0
V_ssi_pin0 _ssi_pin0_3 3 0
M1 3 2 5 5 MOD1
RG 4 2 343
RL 3 5 6E6
C1 2 5 23.5P
C2 3 2 4.5P
D1 5 3 DIODE1
..MODEL MOD1 NMOS VTO=2.474 RS=1.68 RD=0.0 IS=1E-15 KP=0.296
+CBD=53.5P PB=1 LAMBDA=267E-6
..MODEL DIODE1 D IS=1.254E-13 N=1.0207 RS=0.222
..END 2N7000
Supertex
..MODEL 2N7000 NMOS (LEVEL=3 RS=0.205 NSUB=1.0E15
+DELTA=0.1 KAPPA=0.0506 TPG=1 CGDO=3.1716E-9
+RD=0.239 VTO=1.000 VMAX=1.0E7 ETA=0.0223089
+NFS=6.6E10 TOX=1.0E-7 LD=1.698E-9 UO=862.425
+XJ=6.4666E-7 THETA=1.0E-5 CGSO=9.09E-9 L=2.5E-6
+W=0.8E-2)
..ENDS
Philips:
..SUBCKT 2N7000/PLP 1 2 3
Cgs 2 3 12.3E-12
Cgd1 2 4 27.4E-12
Cgd2 1 4 6E-12
M1 1 2 3 3 MOST1
M2 4 2 1 3 MOST2
D1 3 1 Dbody
..ENDS
Ancient MicroSim:
..model M2n7000 NMOS(Level=3 Gamma=0 Delta=0 Eta=0 Theta=0 Kappa=0.2
+ Vmax=0 Xj=0 Tox=2u Uo=600 Phi=.6 Kp=1.073u W=.12 L=2u Rs=20m
+ Vto=1.73 Rd=.5489 Rds=48MEG Cgso=73.61p Cgdo=6.487p Cbd=74.46p Mj=.5
+ Pb=.8 Fc=.5 Rg=546.2 Is=10f N=1 Rb=1m)
Zetex:
..SUBCKT M2N7000/ZTX 3 4 5
* Nodes D G S
M1 3 2 5 5 MOD1
RG 4 2 343
RL 3 5 6E6
D1 5 3 DIODE1
+CGSO=23.5P CGDO=4.5P CBD=53.5P PB=1 LAMBDA=267E-6
..ENDS
I've found two others, from Motorola originally I think.
..MODEL MN7000 NMOS (LEVEL=1 VTO=2.4 KP=.17 GAMMA=1.76U
+ PHI=.75 LAMBDA=1.25M RD=.35 RS=.448 IS=41.6F PB=.8 MJ=.46
+ CBD=44.4P CBS=53.3P CGSO=24N CGDO=20N CGBO=116N)
* -- Assumes default L=100U W=100U --
* 60 Volt .2 Amp 2.5 ohm Enh-Mode N-Channel MOS-FET 11-19-1990
..MODEL 2N7002LT1 NMOS LEVEL=1 AF=1E-26 CBD=0 CBS=0 CGBO=0
+ CGDO=0 CGSO=0 FC=0.5 GAMMA=3 KF=1.2 KP=0.104475 LAMBDA=0
+ LD=0 MJ=0.5 PB=0.75 PHI=0.554054 RD=0.593226 RS=0.593226
+ VTO=1.92518
by Winfield Hill
http://www.electronicspoint.com/ ... aaaargh-t43557.html
from Onsemi:- .SUBCKT 2n7000 1 2 3
- * Model Generated by MODPEX *
- *Copyright(c) Symmetry Design Systems*
- * All Rights Reserved *
- * UNPUBLISHED LICENSED SOFTWARE *
- * Contains Proprietary Information *
- * Which is The Property of *
- * SYMMETRY OR ITS LICENSORS *
- *Commercial Use or Resale Restricted *
- * by Symmetry License Agreement *
- * Model generated on Mar 31, 04
- * MODEL FORMAT: PSpice
- * Symmetry POWER MOS Model (Version 1.0)
- * External Node Designations
- * Node 1 -> Drain
- * Node 2 -> Gate
- * Node 3 -> Source
- M1 9 7 8 8 MM L=100u W=100u
- * Default values used in MM:
- * The voltage-dependent capacitances are
- * not included. Other default values are:
- * RS=0 RD=0 LD=0 CBD=0 CBS=0 CGBO=0
- .MODEL MM NMOS LEVEL=1 IS=1e-32
- +VTO=2.236 LAMBDA=0 KP=0.0932174
- +CGSO=1.79115e-07 CGDO=1.0724e-11
- RS 8 3 1.10523
- D1 3 1 MD
- .MODEL MD D IS=2.71011e-10 RS=0.0140826 N=1.5 BV=60
- +IBV=1e-05 EG=1.16084 XTI=3.00131 TT=0
- +CJO=3.41211e-11 VJ=4.67429 M=0.899864 FC=0.1
- RDS 3 1 2.4e+11
- RD 9 1 0.0001
- RG 2 7 2.18034
- D2 4 5 MD1
- * Default values used in MD1:
- * RS=0 EG=1.11 XTI=3.0 TT=0
- * BV=infinite IBV=1mA
- .MODEL MD1 D IS=1e-32 N=50
- +CJO=7.93181e-11 VJ=0.643298 M=0.9 FC=1e-08
- D3 0 5 MD2
- * Default values used in MD2:
- * EG=1.11 XTI=3.0 TT=0 CJO=0
- .MODEL MD2 D IS=1e-10 N=0.400165 RS=3.00002e-06
- RL 5 10 1
- FI2 7 9 VFI2 -1
- VFI2 4 0 0
- EV16 10 0 9 7 1
- CAP 11 10 1.58786e-10
- FI1 7 9 VFI1 -1
- VFI1 11 6 0
- RCAP 6 10 1
- D4 0 6 MD3
- * Default values used in MD3:
- * RS=0 BV=infinite IBV=1mA
- .MODEL MD3 D IS=1e-10 N=0.400165
- .ENDS 2n7000
复制代码 http://www.onsemi.com/pub_link/Collateral/2N7000.REV0.LIB
http://www.fairchildsemi.com/ds/2N/2N7000.pdf
http://www.diyaudio.com/forums/s ... 9-spice-models.html- Originally posted by Fred Dieckmann
- *SRC=2SJ76;QSJ76;MOSFETs P;Gen. Purpose;140V 500mA
- .MODEL QSJ76 PMOS (LEVEL=1 VTO=-15 KP=122N GAMMA=18.6
- + PHI=.75 LAMBDA=1.48M RD=.84 RS=.84 IS=250F PB=.8 MJ=.46
- + CBD=444P CBS=533P CGSO=384N CGDO=320N CGBO=346N)
- * -- Assumes default L=100U W=100U --
- * 140 Volt .5 Amp 6 ohm Enh-Mode P-Channel MOSFET 07-28-1995
- * 2SJ76, TOSHIBA, 1993 JAPANESE FET MANUAL, P.16
- *SRC=2SJ79;QSJ79;MOSFETs P;Gen. Purpose;200V 500mA
- .MODEL QSJ79 PMOS (LEVEL=1 VTO=-15 KP=122N GAMMA=18.6
- + PHI=.75 LAMBDA=1.04M RD=.84 RS=.84 IS=250F PB=.8 MJ=.46
- + CBD=862P CBS=1.03N CGSO=57.6N CGDO=48N CGBO=1.09U)
- * 200 Volt .5 Amp 6 ohm Enh-Mode P-Channel MOSFET 07-28-1995
- * 2SJ79, TOSHIBA, 1993 JAPANESE FET MANUAL, P.16
- *SRC=2SK213;QSK213;MOSFETs N;Gen. Purpose;140V 500mA
- .MODEL QSK213 NMOS (LEVEL=1 VTO=15 KP=.16 GAMMA=18.6
- + CBD=560P CBS=672P CGSO=26.4N CGDO=22N CGBO=852N)
- * 140 Volt .5 Amp 6 ohm Enh-Mode N-Channel MOSFET 07-28-1995
- * 2SK213, TOSHIBA, 1993 JAPANESE FET MANUAL, P.38
- *SRC=2SK216;QSK216;MOSFETs N;Gen. Purpose;200V 500mA
- .MODEL QSK216 NMOS (LEVEL=1 VTO=15 KP=80M GAMMA=18.6
- + PHI=.75 LAMBDA=521U RD=.84 RS=.84 IS=250F PB=.8 MJ=.46
- + CBD=658P CBS=790P CGSO=26.4N CGDO=22N CGBO=852N)
- * 200 Volt .5 Amp 6 ohm Enh-Mode N-Channel MOSFET 07-28-1995
- * 2SK216, TOSHIBA, 1993 JAPANESE FET MANUAL, P.38
复制代码- What about this one?
- .MODEL 2SK216 NMOS (VTO=-56.0259M KP=20U L=2U W=10.3184M GAMMA=0 PHI=600M
- + LAMBDA=2.12826M CBD=1.80316N IS=10F CGSO=1.13517N CGDO=1.13517N TOX=0 NSUB=0
- + TPG=1 UO=600 RG=50 RDS=1MEG )
- /Hugo
复制代码 http://www.diyaudio.com/forums/solid-state/18257-2sk216-2sj79-spice-models.html
http://140.120.11.121/~lcli/RF/file/sk214e2.pdf
http://140.120.11.121/~lcli/RF/file/sj77e2.pdf |
