发表于 2012-2-27 11:47:34
回复 e3po
仿真软件仿真数字电路,线性电路可能好一些,仿真非线性电路可能不太好。拿三极管来说,教科 ...
yngz 发表于 26/2/2012 19:06
Ebers moll Model & SPICE
SPICE has built-in models for the semiconductor devices, and the user need specify only the pertinent model parameter values. The model for the BJT is based on the integral charge model of Gummel and Poon; however, if the Gummel-Poon parameters are not specified, the model reduces to the simpler Ebers-Moll model. In either case, charge storage effects, ohmic resistances, and a current-dependent output conductance may be included. The diode model can be used for either junction diodes or Schottky barrier diodes. The JFET model is based on the FET model of Shichman and Hodges. Three MOSFET models are implemented; MOS1 is described by a square-law I-V characteristic MOS2 is an analytical model while MOS3 is a semi-empirical model. Both MOS2 and MOS3 include second-order effects such as channel length modulation, subthreshold conduction, scattering limited velocity saturation, smallsize effects and charge-controlled capacitances.
Ebers-Moll Model of Bipolar Junction Transistor
http://www.uncg.edu/phy/hellen/ebers-moll.html
SPICE and MATLAB Simulation on Nonlinear Circuits
http://www2.ensc.sfu.ca/~ljilja/ ... 60_final_report.pdf
The SPICE Circuit Simulator
http://www.eecg.toronto.edu/~johns/spice/part1.html
Semiconductor Device Modeling with Spice
By Giuseppe Massobrio
http://books.google.ca/books?id= ... 20SPICE&f=false |
