发表于 2023-8-23 13:49:41
Serial Number:C02MXTW4FY0T
Model:iMac (21.5-inch, Mid 2014)
Codename:J70
Build Country:This unit was built in China
Build Year:This unit was built in the first half of 2014.
Build Week:Week 26 (June)
Production Nr.:This unit was number 2860 to be built that week.
Processor
Speed: 1.4 GHz
Type: Intel Core i5 (4th Gen) (Haswell)
Model: 4260U
Cores: 2
Bus Speed: 5 GT/s DMI
Cache: 3 MB L3 cache
64-bit: Yes
Turbo Boost: Up to 2.7 GHz
Official Operating System Info
The original OS for this device is OS X 10.9.3 (Mavericks)
The maximum OS for this device is macOS 11.6 (Big Sur)
DOWNLOAD INFORMATION
Unofficial Operating System Info
OpenCore: With OpenCore this Mac can run the latest macOS.
Power
Usage: 100 - 240V AC
Adapter: None
Service and Maintenance (About these links)
Temperature Monitoring: Temperature Gauge Pro (OS X 10.7+)
Security Utilities: Intego Mac Internet Security (OS X 10.8+)
Misc information
New Price: $1099
Ports and Expansion
USB: 4 ports, USB 3.0, 5 Gbps
FireWire: None
Video Out: 2 x Thunderbolt, 10 Gbps
Thunderbolt: Yes, 2x, 10 Gbps
Card slot: SDXC card slot
Storage and Media
Storage: 500 GB, 5400 rpm
Storage Bus: Serial-ATA
Optical Drive: No optical drive built in
Optical Bus: None
Other Media: None
Expansion Bays: None
PARTS
Networking
Wireless: 802.11ac (a/b/g/n compatible) Wi-Fi
Ethernet: 10/100/1000BASE-T (RJ-45).
Bluetooth: Built-in Bluetooth 4.0
Audio
Speakers: Stereo Speakers
Microphone: Dual microphones
Line Out: Analog/Optical combo
Temperature and Cooling
Exhaust: Top backside
Intake: Bottom
PARTS
Apple Support
This device is considered Vintage by Apple
To see if this device had exchange or repair programs for it, Check eligibility here.
Check warranty status here
Size, Weight and Lifecycle
Height: 17.7 inches (45.0 cm)
Width: 20.8 inches (52.8 cm)
Depth: 6.9 inches (17.5 cm)
Weight: 12.5 pounds (5.68 kg)
Introduced: June 2014
Discontinued: October 2015
Memory
Installed RAM: 8 GB
Max. Amount: 8 GB
Number of slots: none, soldered on board
RAM Speed: 1600 MHz
RAM Type: PC3-12800, LPDDR3
PARTS
Graphics
Display Size: 21.5-inch
Graphics Card: Intel HD Graphics 5000
Card Memory: Up to 1.5 GB shared
Maximum Resolution: 1920 x 1080
Backlight & Coating: LED backlit with IPS
Camera: Built-in FaceTime HD camera
Model Information
Model Identifier: iMac14,4
Model Number: A1418
Order Number: MF883LL/A
EMC Number: 2805
Continuity and AirPlay
Calls & SMS: Supported
Handoff: Supported
Hotspot: Supported
AirDrop: Supported
AirPlay: iTunes & Mirroring
Health
Vision: f.lux (OS X 10.7+) |
